hi guys
im replacing the injector fuel line set up. its the set of pipes and plug things, that go across the tops of the injectors, looks like theres a small pull out clip that holds them in. reason is my car has had problems starting and told it was down to run off, over nite fuel going back to the tank. is it a hard job and could you tell me if theres anythink i need to look out for.
thanks for any help
thanks for any help
