BigDusty
tamrsoft said:Mine has the same P/N (094 00 48) and is made by Pierburg. As stated in the last article, it can be removed very easily by removing two small torx screws and extracting the unit from the air filter casing.
I remove mine regularly and give it a blast with an electronics component spray (do not use anything else) to clean off any crude which is usually a light oil deposit. Just hoping this will extend its life and avoid the outrageous £60 replacement cost.
Do you know where I can get one of these Pierburg probes from to fit the (094 00 48) and it has the round cable connection not the square.
