I don't have any pickies of it unfortunately as both times ive fitted them on the newer of our cars ive been in a big rush.
Remove the split pin on the top of the pedal and it should full forward. Pull the rubber up towards you and give it a helping hand over the bumps of the pedal itself. Slide the new one on and put the split pin in.
Warming the pedals in water helps beforehand. I would recoment puting them into a foodbag or similar before puting them into water as it was extra time to dry the pedals off.
If you get stuck ill take a pickie of my W203 with the similar pedal setup as i snaped the split pin on it and it just slides out.
