any suggestions on a sub in clk cab?
shaz_duf
north west
clk cab
i bought a w208 clk 2002, a few months ago and recently upgraded the standard audio 10 cd player to pioneer avecx1 dvd/sat nav package! the sound quality has improved drastically, however still lacks that extra bass! i have been thinkin about installing a sub in the boot but am hesitant because of loosing the boot space, minimal as it is! has anyone built or any suggestions of what i could do install a sub in my clk?
Are you a bass head or just want something to fill in a bit ?
The infinity basslink is a good active sub that doesn't take up too much space, it'll give you a thump but you wont blow windows out of buses with it....
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='BASSLINK'&Ser=BSL&Cat=PSU
Good value all round !
Good luck
thanx, do u suggest an active sub? ive been lookin at the pioneer bass tubes or the spare tyre sub that pioneer manufacter, but unsure if they will give any bass in the boot!
Active is the way to go to take up less space, the spare wheel well one i'm not sure about, as it sometimes helps the bass depending on where you position your sub in the boot, and you won't be able to move the spare wheel one.
Active is good, as there are no wires trailing around, or seperate amps to bump or anything , if you want to take the active sub out of the boot to save space, you just unplug it, whereas if you had a passive one , you will have speaker leads containing amplified current coming off the amp to contend with.
Not sure about the w208 clk structure ( we have a 430 but i have never taken it apart ) , i know on our w124 the petrol tank is behind the rear seat and it is a nightmare to get bass out of the boot and into the cabin..... being that yours is a cabrio. i would expect there to be reinforcing behind the rear seat which may pose a problem too ... best thing is to take the trim off in the boot and have a peek....
thanx m8 i will have a look tomorrow and get back to ya!
Hope it goes well :rock:
has anyone else fitted a sub in a w208 cab? if so plz can u help!
