Anyone done their own disc and pads change W212 E63?
MOR8A
Sussex
W212 E63 PPP AMG
Just wondered if anyone has had a crack at doing their own ? I did them on the E55K with the bonkers SBC setup and managed to keep all my fingers. Have not done any research on the new cars set up, any info would be gratefully received. Ta.
Mor8a things have chenged a little with brakes from years back. My advice would be go to youtube and check on the videos .You will see how its done then .And you can make up your own mind ,thats if you think its possible for you to tackle it . .
I understand that tech has moved on, but is there anything ''technical'' to stop one doing it one's self?
Done ours on a W212 E250, no problem other than getting the discs off.
Needed quite a bit of muscle and brute force to get them off, they were kinda rotted through and had a lot of debris in the middle.
We just disconnected the battery and left this off while doing it, syringed off a bit of brake fluid when pushing the pistons back in and replaced this when done.
