Lee C63
Just had a Water / meth system fitted to the C63….main reason for this was to help control IAT (even though I have a Killer chiller installed). I opted for the HFS 4 Aquamist kit which will allow me to have the ECU map finely tuned and may give a slight increase in power (due to the Meth raising the Octane level of the fuel slightly). However, I won’t hold my breath on seeing any noticeable power gain.
Very happy with the install, which was carried out by Stan (Stans Autos in South Shields) and I am currently having a pod custom built into a A pillar panel to see if it looks any better than the pod on the dashboard. Originally I was thinking of hiding the Gauge out of site. Hiwever, it’s a good visual indication that everything is working OK and can be finely tuned if required.
At the same time I also changed out all the fuel injectors (having had 2 fail recently) and also installed Weistec spark plugs which are a Range colder. I was quite impressed that Weistec give a specific torque for the plugs which ensures the “electrode tip” is orientated correctly in the cylinder for maximum efficiency. Might be just my imagination but the car seems more responsive and feels like its running smoother???
I took it out for a quick “ run” and was impressed to see the IAT drop to 25 degrees at full throttle which is a significant improvement.
I would say that Water Meth is probably not required for a N/A C63 but with forced induction and the well known issues with heat soak I think it’s a worth while mod.
Big thanks to Stan and his team for the work (He has also installed the same system on his S63).
IMG_0593_zpsacqhjx6p.jpg Photo by leehanson110174 | Photobucket
IMG_0592_zpshflmvfgy.jpg Photo by leehanson110174 | Photobucket
IMG_0591_zpsxi4ybkic.jpg Photo by leehanson110174 | Photobucket
IMG_0590_zpsefjt1s2q.jpg Photo by leehanson110174 | Photobucket
