After 2 days with no snow issues - I got stuck on my drive twice at the weekend - most suprising becuase it's flat - well that's flat apart from the depressions in the gravel where the car sits.
I'd parked 9in to the left of where the car was went it snowed, so the passenger side was on snow/ice and in the drip. Drivers wheel was on tarmac (other 3 on the gravel). Started car, put it in reverse, feet off the pedals, ASR cuts as the passenger rear slowly rotates. Tried W, tried some gentle throttle, ASR off, but id didn't want to come out of the depressions. Got out and chucked a handful of loose gravel under the tyre and it rolled out no problem. After the second time, I got the yard broom out and swept the gravel to level the drips.
Anyway to the point, I questioned myself afterwards, why wasn't the ASR dabing the brake on the passenger rear and allowing the power to go through to the drivers wheel, which being on tarmac would have pulled the car out. The ASR does dab the brakes on a spinning wheel (and cut the throttle) doesn't it? Or does it just cut the throttle? Or was the cycle happening too quickly/aggressively that there was never enough power going to the other wheel?
Apart from this, when moving, the ASR has been excellent in the snow any slight rear end twitches are bought rapidly under control, with only a little input from me to correct the direction the car is pointing in. In just doesn't seem to cope with being stationary with one wheel on ice the other on tarmac - which I guess in understandable, as it's a fine balance between not allowing the car to move off because the brake is applied to hard to the "spining" wheel, and not applying it enough to allow power to go to the other wheel.
