CHRISCHANCE
I read on here that the securing clip on the ATF filler/dip-stick tube is coloured black when it leaves the factory and subsequent ATF checks by services is replaced with a red clip.
Today I broke off the BLACK plastic clip, which means my gearbox hasn't been checked since leaving the factory 15 years ago! (118,000 miles).
I checked the ATF with a dip-stick and found the level to be OK, but the colour of the ATF is worrying me - it is very dark.
I've bought a servicing kit - filter, oil and gasket but I am now worried that a complete flush with new ATF will cause problems with clutch pads losing grip and valve body channels blocking because the new ATF will clean the system/channels and may cause a blockage.
If I do just a change rather than a flush, I think I am merely contaminating the new ATF with the old in the torque converter, hence the quandary - what to do?
Because the servicing record is up to scratch with MB services, am I to think the ATF is a 'lifetime' item because the existence of the black plastic clip means the ATF has not been checked on any of the recorded services?
