Auto Box Dipstick
Paul Grainger
UK
SL55, Porsche 996 C2 convertible
Does anyone know the MB part number for a dipstick for a late 1999 tiptronic auto gearbox? My stealer isn't being very helpful.
I have read on other theads in this section that these can be purchased from MB. I want to check my oil level, and am contemplating changing it. My car has done nearly 50K miles, as an engineer I don't support MB's opinion that it 'is sealed for life and does not require changing'.
Paul
the dipstick is there but it has a tamperproof seal afaik you need to break seal and pull out the plug, it should have a dipstick attatched.
I know this is how it is on the W202's
I tried breaking the seal.....no dipstick.
Thanks anyway....
Paul
Hi Paul, I can't aswer your question specifically but when I last took my CLK (with the same gearbox as yours) to George Fraser for a service, he said the oil in the 'sealed' tiptronic gearbox should be changed every 3 years.
I come from a mechanical engoineering background and simply don't believe oil (even the newer synthetic types) can last a 'lifetime'.
part number for autobox dipstic is 140 15 21
regards Glynn.
Thanks for you help. Will try stealer tomorrow with this part no.
Paul
regards Glynn.
you're missing a couple of digits off that I'm sure.
you could be right,these are numbers on the actual tool,but there may be some in front to indicate it is a special tool??
apologies if it is not complete
Wonder what I end up with now I have asked a main dealer to change the box fluid. Probably a knackered box and no dipstick.
The part number is W140589152100 Measuring stick.
It is way too long and is a service part only. It cannot be left in the box while driving. Push in all the way till it stops for measuring.
Thanks for that.
Paul G
