That transmission fluid appears to be made by
Kuwait Petroleum and from their website appears to meet MB specs :-
Q8 Oils :: Kuwait Petroleum International Lubricants
and according to this spec sheet meets MB approval:-
Q8 AUTO 15 AUTOMATIC TRANSMISSION FLUID - 25LTR
Q8 Auto 15
Product Data Sheet
Description
Automatic transmission fluid
Application
In automatic transmissions of most passenger cars, busses, off-highway/construction and military equipment as well as in selected manual transmissions
Also suitable as power steering fluid and as hydraulic fluid
Q8 Auto 15 may be used as automatic/manual transmission fluid or power steering fluid when one or more of the following specifications are used to describe the required lubricant quality:
#General Motors Dexron ® III G-34052 (automatic transmissions)
#Ford Mercon ® M 931004 #### APPROVAL (test met #-tekens als commentaar)
#Allison C - 4, C4-18741793 (automatic transmissions)
Mercedes Benz 236.1, 236.5, 236.10, 236.11, 236.12
#MAN 339 type Z-1 (previous type F)
#MAN 339 type V-1 (previous type F)
#Voith 55.6335.20 (previous G 607) DIWA D85.., D86.. and D502-type automatic transmissions(with retarder)
#ZF TE-ML 02F (Manual and automatic transmissions for Buses and trucks)
#ZF TE-ML 03D (Converter transmissions for off-road equipment)
#ZF TE-ML 04D (Marine transmissions)
#ZF TE-ML 11B (Manual and automatic transmissions for cars)
#ZF TE-ML 14A (Automatic transmissions for commercial vehicles)
#ZF TE-ML 17C (Transmissions and axles for lift-trucks)
#Volvo 97341:010
#Chrysler ATF+3
#TASA
Benefits
Universal automatic transmission fluid
Approved for use in GM continuous slipping torque converter clutches
Provides immediate lubrication after cold starting
Incorporates well balanced friction modifier system
Possesses excellent oxidation stability
Limits transmission wear and extends transmission life
Provides continuous smooth power steering
Protects against rust and corrosion
Good elastomer compatibility
Properties
Method Units Inspection Data
Absolute Density, 15 °C D 4052 kg/m3 862
Kinematic Viscosity, 40 °C D 445 mm2/s 35.8
Kinematic Viscosity, 100 °C D 445 mm2/s 7.7
Viscosity Index D 2270 - 200
Brookfield Viscosity, -40 °C D 2938 Pa.s 18
Flash Point D 93 °C 176
Pour Point D 97 °C -48[/QUOT
i know this is an old post, will this be ok in my e55.Anybody using it also do you think mine will have t/c plug to remove its a kare 99 model.
Many thanks
