Hi Guys.
Three times in as many weeks the BAS and ESP warning has come on after starting the car ( 2000 CLK320 W208), everything seems normal and operates correctly.
This happened last on Saturday, when I had the opportunity to see if the cruise control worked normally, which it did.
From reading on here, it would seem to indicate that I have a faulty brake light switch.
What do the wise ones think, is this the most likely problem?
If so, can you tell me where this switch is located and if there is a specific one I need for my model/year.
Many thanks in advance for any help in locating the switch, both in my car and a suitable replacement
