WDB124066
- Apr 17, 2009
- 1996 E320 Sportline Cabriolet x 2
Yes, how to adjust that, it's a strong blighter.
Thanks for the link JJJ.
Regarding rear camber adjustment, take a look at this set up on an early AMG wagon, looks to me like an adjustable spring link that will control the rear camber, be nice to retrofit that to our cars, I'm ever so slightly over the rear camber tolerance with the reds in...
If you look closely at the picture, the LCA bushing bolt is not centered, appears much like the eccentric LCA bush design from K-MAC.
Ed A.
Yep, either that or they've slotted the lobe similar to the front. I am not too sure why you of all people were confused by my earlier post...??
If you don't like any of those methods you can always plug the outboard hole and drill it closer to the inboard hole - but you will need tight control over what you are doing if you go that route.
@ Billy, you can adjust rear camber by adjusting the length of the upper or lower link.
I prefer the lower spring link adjustment method.
Here are some Mercedes-Benz training notes for the rear suspension on a 201 which is virtually identical to the 124. See the inboard springlink bolt - it's a cambolt.
I wonder if this was the old way of adjusting rear camber but it was discontinued due to being able to hold tighter manufacturing tolerances...??
Interesting..3A and 4A are eccentric which can only be for adjustment.
3A appears to be a camber adjustment ?
..interesting
i didn't know the lower control arm can be adjusted as well??
If i'm reading the above info correctly, am i able to move the bottom control arm inwards slightly..?
Now...check this out up front.
This is how the car sits with the current springs that gave me perfect lowering with the 220 lump. (was using a 2 nib pad 13mm)
With the 3.2 lump in and the same springs even with the thickest pad of 23mm that car is slammed dunked!!
looks very cool though, i'm only going very slightly up from what you see here.
