Blackberry 8707G in car kit for W211?
TheGrocer
Kent
E320CDI 04 AvantGarde
Does anybody know if the Blackberry 8707G has a phone cradlle that will fit into the W211 center console? Do Merc make one and is it compatable with Comand system.
I think you will have to go the Bluetooth route. The W211 changed to UHI mid way through 04 so depending on whether you have UHI or not will dictate the solution.
If UHI then a replacement Bluetooth HFP cradle is needed. If not UHI (curly cable inside centre consol) then Viseoo is the solution.
Suggest you check www.comandonline.co.uk
SargeBenz
what SARGEBENZ has said is correct. As far as i know there were no cradles made for blackberry devices and therefore your only was is to go down the bluetooth route.
If your cradle is currently fixed (i.e 6210, 6310 etc), your easiest option is the viseeo kit
If your cradle is not fixed and you have aUHI connector then you either have the option of the HFP cradle or the viseeo. They are both very similar however the viseeo allows you to send your contacts manually Iso they show up on your screeen) if they do not automatically synchronise with the phone.
both available on www.itjustworks.co.uk
Alfie sells the viseo bluetooth cradles too..
