Brake caliper fixing, size etc
DSM10000
MB Club Veteran
Near Salisbury
MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
Would anyone know the size of bolt and type i.e. torx or hex head etc for the brake caliper fixing for a 2003 W203 320 saloon?
I ma pretty sure I have most szes but if not I can pick up the correct one after work this evening.
Thanks.
David
mazza
Thank you.
I posisbly was unclear in my post, what I need to know is the size of socket / torx bit required to remove these bolts. Also, whilst I remember is it advised to use loctite and to what torque setting?
Sorry fdr any confusion.
David
mazza
Thank you.
David
Hi
I cant remember right now but I think its a HEX size 19
Loctite is a must or new bolts
torque shoud be something like 115 newton meters
mazza
Thank you
I cannot find a 19mm socket in my tool kit, have a 19mm combination spanner! so off to the tool shop tomorrow.
The calliper is held onto the carrier with either a 6mm allan key or a T40 Torx socket. The carrier to hub bolt sizes can be either 18 or 19mm.
Thank you.
I am assuming the caliper carrier needs removing to change the disc?
Yes it does. Easy job too. Before fitting the disk make sure the hub is clean and put a little copper slip on the hub face after. You might find that the disk wont fall off as it should. A sharp rap with a copper hammer usually frees them.
Just to note, I have the Lucas caliper, I found that is held on to the caliper by 12mm bolts and my carrier had 18mm ones.
Just need to get the disc screw out now!:wallbash:
