There is a Convenience Control unit under the back seat, it contains 8 relays, one to raise each of the windows and one to lower each window.
When you push the driver’s window switch for DOWN, the switch energises the driver’s down window relay, the relay points close and deliver power to the motor to lower the window.
When you push the driver’s window switch for UP, the switch energises the driver’s up window relay, the relay points close and deliver power to the motor to raise the window.
Having 2 relays for each window reverses the polarity so as to enable the window motor to reverse direction so as to raise or lower the window.
One possibility why your window is not coming down… if its in the fully up position… is that the relay that is responsible of bringing it down has a dirty or burned points and so preventing the motor receiving any power.
You could open the cover of the Convenience Control as pictured below, don’t unplug any of the plugs, the unit will be live even if the ignition is off so don’t let it touch any metal. With the ignition on, close each relay points with your finger to ascertain which relay belongs to which window or operate the window switches, each relay will click when its switch is pressed, this will identify which relays belongs to which window.
When you identify which relay belongs to the driver’s window you will need to check that that the relay points are clean and undamaged, it will be the down relay for the drivers window that may be faulty… that is, if the drivers window is in the fully up position when you are testing it.
The above is a plausible explanation as to what’s at fault, however it could be something else that’s the problem, like the vacuum pump or the window motor.
Dec
Dec
