chizzel89
- Mar 29, 2010
- Location
- Pembrokeshire
- Mercedes-Benz C250 Turbodiesel Sport est. 155,000 mls. Peugeot 405 1.9 GLX TD Estate- 280,000 miles
Hi all, been having some annoying fuel delivery related symptoms with my newly aquired C250 TD Sport.
When I picked it up it was running B100, and seeing as its had the common prep work needed to run bio/ wvo blends (new O-rings on the push-fit pipes, shut off valve and decent glow plugs, as well as a spot-on engine which starts almost instantly from cold after the glow light has extinguished) I decided to put in 20ltrs of my finest WVO with 10% petrol mixed in.
There was just under half a tank of B100 in there when I poured in 20ltrs of WVO blend. Obviously I've researched the idea of running WVO blends in an unmodified OM605 extensively, and talked to several people who run this exact blend of WVO/Petrol long term with no problems at all.
Anyhow, the symptoms are mainly during kickdown. When the box changes down, the car initially picks up well as it should, but at 3-3.5k rpm it starts to surge back and forth a bit (just like my old pug did when it was struggling to pull in the fuel). Taking it up to the kickdown change point (4. something rpm) is a labourious and worrying task and I just avoid it now as I don't want to damage anything (lift pump for example).
It will do it a little after pushing it hard up a steep hill (giving it some welly, but not on kick down) too.
So far I've changed the pre-filter (and after market disposable thing just before the main filter) which was quite cruddy, so I'll change the main filter tomorrow and check the small witches hat pre-filter under the bolt.
I'm reliably informed these cars don't have a tank strainer, so atleast I won't have to get underneath the car just yet!
Is there any tell tale signs it could be anything else?
I imagine if it was the lift pump, the car woulnt be starting so very well as an ailing lift pump would let the fuel drain back/ leak?
Thanks in advance
Thanks in advance
