Yesish. It can all be done here. I have a brilliant SS welder.
What were you after?
I had a friend remove the cats and he bent the pipes insted of using mandrel bends, also Kleemann header joint cut off and replaced with V band. stock resonator removed and small silencers put in.
I'd offer mine up but mine has had this treatment already.
However, the job wasn't as well done and I had to have a rattle sorted by my local inde as whoever did it originally used mismatched pipes of which one knocked into the other internally.
How much does it cost (I might consider doing one of these and replacing the back boxes with the Meisterschaft ones at the same time!)?
Go Eisenmann mate, I can get you a good deal..
