Hi All,
Hopefully this is the right section...
I've owned my C63 AMG Estate for just over 2 months now and everything has been generally excellent. Car was purchased from Mercedes Benz Direct.
In early July the car wouldn't start after being sat on my drive for 2 days. Upon investigation by Mercedes Roadside assistance it was discovered that the starter motor fuse had blown. Chap replaced the fuse and all was well. He advised that should it do it again to take it to Mercedes.
Few days later again after the car had been sat for a day the car wouldn't start and the fuse had indeed blown again. This was during the wet start to July so I immediately thought this was something to do with the rain.
Car was taken to Mercedes and no obvious fault could be found although I was told that some conduit and connectors that may have allowed water ingress to occur had been repositioned and sealed. Great I thought, car was subsequently fault free for 4 days but again after being left for almost 2 days the car wouldn't start and the fuse had blown again.
Car is back with Mercedes now and I'm starting to think that perhaps when the car isn't being used for a period of time some kind of resistance is occuring in the starter motor which upon start is drawing too much initial current blowing the fuse. As the motor has been freed up replacing the fuse cures the problem.
I'm pushing for a new starter motor assembly under warranty but the dealer is saying that if no fault can be found no claim can be raised.
Has anyone else had this or a similar issue?
Cheers,
Serk
Cheers,
Serk
