ecain63
- Dec 31, 2015
- Location
- Bournemouth
- '62 C63 PPP Saloon. Red. V5 Map. Remus exhaust. 181mph at Vmax stealth
Correct me if I am wrong please.
Might be worth making this a sticky.
There are 3 different specs of FRONT brake discs available for the C63 if my googling and memory has been accurate. Note it's only the fronts.
Standard 457bhp C63, 2008>. Has a solid steel, cast disc. Drilled and vented. These are very reasonably priced. The rears are the same construction only smaller.
The 2008/9 Performance Pack (not Plus) cars had proper 2 piece discs. An aluminium floating bell which bolts to a steel rotor. The rotor is drilled and grooved. Rears remain the same as standard car. The bell is black which makes it easy to spot:
The 2010> Performane Pack Plus, DR520, 507 and Black Series (by the looks of google results) have a composite cast disc. This has a cast aluminium bell with a steel rotor. But, it's a one piece construction thanks to cast arms which fuse the two parts together: The disc is grey / silver all over. Again, rears remain the same as the standard car:
Eddie
Eddie
