99% COMPLETE
That is how I would describe the car after Uli's latest fettling.
Seriously, I can't stress enough how well my car now rides! That's right, I'm talking ride quality
Going down the road it's just so smooth and you don't need to avoid holes or scarred surfaces and over really small, high frequency bumps (those that you often get on side roads and would knock a stiff car all over the place), this just absorbs them. It doesn't float over the road though...you do still feel the road but it deals with bumps and ruts in one well controlled movement which has to be felt to be believed!
Indeed, so good is the ride that you'd think the car will roll or be soft. Well no...Uli has managed to get the holy grail of a good ride and almost flat cornering...mainly, I believe, by using the rebound adjustment to control the roll angles.
Very effective tuning - using quite a supple compression to give a good ride and ability to deal with mid-corner bumps without getting any deflection, and using the rebound adjustment to literally 'pull' the car flat in bends.
So, why only 99% complete?? Two reasons....
IMO, it sits a little high at the front so I'm going to get Uli to take out another 5mm or so from the front ride height (it's currently very similar to standard so it's never going to be on the floor!). And didn't my poor friend know about this...I kept ripping into him today saying its so high he may as well of bought back a Range Rover for me
Also, like most new Mercs are known for, it pulls to the left which is a bit more noticeable now the car responds so much better to steering inputs. This is apparently designed-in for safety reasons (incase you fall asleep at the wheel, the car pulls you into the kerb
) but you can get a set of adjustment bolts from Mercedes to ensure you can align the car 'perfectly' and dial out this design flaw. With any luck, this will all be completed by next weekend!
