Simon_M
Well I am paying £1200 for carbon mirrors so I would say £1600.
Either way, I need one.
Simon
Simon
Palmball, thanks for posting this graph.
I am surprised that they have opted for such a rich mixture at high revs, it is generally accepted that maximum power is achieved around the 12.3:1 ratio.
From your graph, you can see the AFR's up at 14.5 at low revs (this is probably still ECU controlled closed loop mode - due to small throttle opening, and low load). Then AFR drops to around the 12.0-12.5 mid range, which is ok, but I think going down to such a rich mixture (low 11's) on a normally aspirated car is playing it very safe.
You would normally see low 11's late 10's on a highly boosted turbo engine. This extra fuel is being used to cool the combustion chamber and reduce the chance of detonation.
A good mapper would be able to take some of this fuel out, and get a few more ponies (less thirsty ones too)
I guess I should have expected such a rich brew on a generic map.
At full chat there is going to be a fair amount of unburnt fuel going down the exhaust, which will probably ignite in the CAT's and get them very hot. O2 sensors and exh. manifold won't be liking that heat either.
Good news that Brabus are going to refund. :bannana:
Hi Chaps
Just a quick hello interesting post this ive got a c63 arriving sept 1st, just standard no PPP or LSDiknow but its a lease car hence just wanted cheapest deal.
Obviously i dont want to spend much money on it but will probably go for delimit and remap, anyone had any dealings with DMS ?
After reading Palmballs posts il probably give CPR a shout as there not far away
Is there anything else that i should be aware of (besides tyres) reguarding running car ?
Thanks in advance Lee![]()
Hi Chaps
I'm a bit confused....
I was under the impression that "our" 6.2 motor was just an electronically restricted 6.2 motor that is found in the more powerfull AMG cars, such as the E63. They all produce (according to the marketing bumf) 525hp. They do not have the SLS internals either.
If that assumption is correct, how come the PPP engine cannot be made to produce at least 525hp with just a basic "E63" map? Are there other components in the other 6.2 engines that give them the higher power output that Mec hold back even from the PPP 6.2 in the C63?
Hope that makes sense
Jack
There's three reasons that I think explain this!
Firstly, the 525 figure is actually PS and is often misquoted as BHP. This means that they produce a claimed 518bhp. However this still makes the E's, SL's etc have a claimed output some 11bhp more than my 'real' figure in standard tune.
Secondly, the other models don't appear to make quite the quoted power - when at CPR, Max showed me a variety of dyno runs for other models including an E63 (W211) and an SL63...both of which AMG claim to make 518bhp. Neither of them made as much power as my car in standard tune - indeed, the SL made as little as 480bhp. They said my C63 (pre-Brabus) produced the highest figure for a standard '63 engine AMG that they'd seen so those fancy internals must be worth a bhp or two!
Now, the variables between AMG's quoted figures and the dyno results shown to me can be explained by the fact they would be measured on different dyno's and use different fuel so in reality, a different brand of dyno or the use of V-Power instead of 95-ron supermarket fuel could see the power get much closer to the claimed figure for those E's and SL's.
In the example above, the comparisons between my car and the dyno graphs of the other models were all measured on the same dyno...but of course I can't speak for the conditions or fuel used so it's not a perfect comparison.
What I can 100% confirm is that my before and after measurements were done on the same dyno, using the same fuel and in pretty much the same conditions so they really are a like for like.
Thirdly and finally, the dyno assumed an approx. 18% transmission loss so my 506.9 flywheel bhp is based on 415 rear-wheel hp divided by 0.82. This again isn't an exact science so cannot be 100% compared with AMG's claimed stats hence the only realistic comparison can be same dyno, same fuel, same conditions which is what i did with my pre and post Brabus runs!
Now, I'm starting to confuse myself so I hope some of this makes sense!
I'm confused...
Were you pulls done on a chassis dyno?
Chart indicates "ATFW" ( at flywheel ? )....this reading is only accurately recorded on an engine stand.
Not sure why a chassis dyno which reads RWP would convert to ATFW.
Also was it an inertia ( dynojet type ) or load ( Mustang type ) dyno...
Inertia dynos typically show a 15%-18% drive train loss where as a "real world" load dyno will show closer to a 30% drivetrain loss...
I'm confused...
I'm afraid it is not as simple as a % loss of power.
Take a gearbox/Propshaft/Diff, etc being driven by an engine at a particular speed.
Now if you double the power of that engine at the same speed, the gearbox doesn't suddenly want twice as much power to drive it. Sure it needs more power as extra strain is put on the gears, etc, but much less than double the power.
At the end of the day, the power at the wheels is what matters. Who cares what the engine is actually producing, that figure is for bragging down at the pub. And when you are down the pub, there is always going to be someone who knows someone that has a 1000bhp Skyline
Palmball, 415 at the wheels is a good strong number![]()
As I said it was done at the wheels and the flywheel figure was estimated using an 18% transmission loss. I appreciate this isn't an exact science but I never intended for it to be a comparison against AMGs claims. It was merely to measure a before and after Brabus tune and given the same rules applied to both, it did it's job! Hence I'm now sat in MB Milton Keynes getting it removed and my money back
The dyno used was Dyno Dynamics and they all have the capability of working out an estimated flywheel hp using pre defined (and again estimated) transmission losses. Not a perfectly scientific solution but as a means to compare different tunes on a car it does the job as long as the dyno operator can ensure consistency in the way they perform the run.
Not sure what your point is......
Basically I questioned why any CHASSIS dyno converts RWP to read ATFW.
There is drive train loss which can be accurately calculated by performing a base line pull and compare with the published fly wheel figure which the manufacturer obtains from an engine stand / dyno.
The RWP number is a direct result of drive train loss..power output starts at the flywheel...
As I clearly stated the RWP will be higher on an inertia dyno versus a load dyno...
So the RWP will vary from the two types of dynos by as much as 15%-18%....
The 415RWP is an excellent number...stock CLK63 BS typically around 432RWP.
Lol - I have been considering the Kleeman but having looked into that further, to do it properly needs ECU, Headers and Cats...and thats even more money than the Brabus option. I'm currently debating this in my head but I am very nervous about non-genuine engine changes on such a new and in-warranty!
With regards to AMG doing the upgrades, I already begged and pleaded with them for both the engine and diffuser when I had my interior done and they are not in the slightest bit interested. I guess these days they are no wholly owned by Mercedes and not independent so are going to be very straight-down-the-line corporate rigid!
Wow, getting some popcorn and a comfy seating position ready for the next instalment.
Who is making these new headers and Cats? AMG?
Just so I get this right, they are going to fit 75mm headers (tubular tuned versions or cast log type?), sports cats, and full exhaust system, or couple to the existing exhaust? What diameter are the standard pipes to backbox?
2x 75mm is very very large for a normally aspirated engine, in fact 2x 52mm is large. Too big and you lose the back pressure required. Will be interesting to see the results.
To put the proposed size into perspective, a 600-700 Turbo charged engine will be OK on a single 3" exhaust. Just slightly choked at the 700 limit.![]()
