C63 weird at speed
MrPoseidon said:
Any update on this chap ?
Had the car on the ramp some of the front bushes slightly split on the control arms but no play which would cause the car to feel like it does.
Same with rear no play had pry on each arm and joints at both end and bushes are all fine.
I've just added some more air to the rear tyres was running 39 now at 42 to see if that makes any difference never have any weight in car only 2 passengers 90% of time.
Thanks for update Gledsyc63 - so it appears it's just an inherent problem with our cars !
Mine seams ok up to the end of the clock never had an issue with it!
Gents,
The car is in for its B service and MOTtomorrow at MB Wakefield. Going to ask them to check out all thats been mentioned previously on this post. Lets see what they find?
So! just got back from the dealer after its B service and " nothing wrong with the car at all sir , everything you asked us to check is fine, no play in any of the bushes at all, but the service technician has picked up that you could do with new wiper blades ".
The only thing I have noticed after looking through the service is that he has put all the tyre pressures up to 44 psi?
