Car still slow after MAS change
PeterE320Cdi
Devon
C219 CLS 320 CDi, R170 SLK 230K, XC60 Past Cars: S210 E320 CDi rusty, CLK 240, S210 E300 DT
My E class has been getting slower and slower so having read the various MAS/MAF posted I decided to get a new one from the Mercedes dealer. Fitted it last weekend and the car was better but still not as it should be.
If I floor the accelarator it kicks down but will then change up at about 3,500 revs where before it would not change till around 4,500.
Do you think I should take the MAS back and ask for a different one or are there other common problems I should check?
Cheers, Peter.
It will be a MB Pieburg one ;)
Check for air filter blockage, cat blockage, leaking turbo pipes, EGR Valve and inlet port motor. Did i miss anything :D
My reason for asking was that there are some odd make replacements out there that do not last 5 mins
Measure the voltage from Pin-5 of the MAF, just under 2V at idle and approx 4.5v at full revs.
Being a parts jockey will just get expensive with no reward.
I'd go with blocked cat if it has one.
Its says in the 1st post about acquiring it from a MB dealer :D
I have the same car, i bought a MAS from MB and its Pieburg so i assume they're the same!
Leaking vacuum system ?
Pressure converters ?
What is boost pressure level ?
Power increases “hand in hand” with boost pressure.
If pressure don’t reach max level, power neither.
What about smoke ?
If boost pressure leaks, mostly there are lot of smoke too.
If there is nothing in “false memory”, and no smoke.
It might be some kind of boost pressure-problem.
Maybe “learning “ transmission learns to change earlier, when it sees, that engine have poor power.
When you get the power back, the transmission will be ok, too.
Yes I re read it last night so the fault will be else where and Dieselman could be right with blocked CATs
Thank you everyone for the advice. I went on a 60 mile drive yesterday and it has cured the problem. I can not think why a longer drive would have sorted it so fingers crossed its not an intermittent problem.
Cheers, Peter
