Change Key Fob Casing
itjustworks
Hello,
Hopefully someone can help here.
My car key (C270 CDI 2003) has gotten very grubby so I have ordered a new Key Fob casing from eBay.
I was wondering if anyone had instruction or links to a video to help me take the current one apart and remove the inners.
Any help much appreciated
hi, you cannot change key FOB and install it in another it has to be done via mercedes. It has to be digitically programmed into the new fob. Last time ive asked for a quote it was around £175 + VAT
Buying from ebay is a NO NO..... as they never work.
hope this helps
If you're changing the electronics as a whole, there should be no need for any programming. Obviously required for a complete new key, but just a change of external plastics? I think not.
Of course, whether you can get the key apart and reassembled without breaking anything is a totally different matter.
Rock - it's quite possible to swap the innards of your own key to a new casing - no need for dealers or programming.
Itjustworks - you need to extract the innards of the key, as if you are going to change the battery. If you remove the skeleton key from the end, you'll see a small plastic tab which needs to be held over whilst you pull or prise the top casing part out of the main casing. After that, the circuit board is just clipped inside the main housing. I'll try to post a couple of pics later, but I can't at the moment, because my main PC is having a wobbly. Alternatively, you could try searching the forum, as I'm sure there's been one or two threads about this.
Would be interested in seeing how to do this. My wife has managed to drop both of my keys and crack the IR lens!! :doh: The keys still work but it's just annoys me!
+1
Yes, it's exactly as described above (only so long as the key you're replacing is of the same type).
For example, you can't swap the inside of the black plastic key with the new style chrome one as the PCB is a different shape. If your keys look identical it's just a case of swapping the parts over.
