>> Draining has to be better...
Why?
Show us some **evidence** of premature engine failure because of using a vacuum pump to remove the oil.
I could squeeze a bottle of ketchup into my engine and it wouldn't cause premature engine failure, but it doesn't mean it's the correct thing to do.
When you drain it using gravity and the sump plug at the lowest point, you get more particles of dirt, general engine crap out.
Sucking the oil out is a comprimise and from the units i've heard about (I've never used the small electrical ones myself, only larger more industrial based pumps) it is far slower aswell.
So the pros and cons......
You stay cleaner with the suction method
You can drain directly into a container to get rid of the oil correctly
No need for ramps
No need for sump plug washer
More expense on buying the pump
Less oil is changed
The particles of dirt, metals (We are talking very small amounts here, i'm not saying you have a bag of sand in the sump) are not sucked up as much due to that evil bitch gravity.
If i'm doing an oil change, I want to change as much of the oil as possible, not do a partial oil change and lose some of the benefits of it, sucking it out is a comprimise due to time or packaging constraints.
Dave!
