May 11, 2011 #1 diandave Active Member Joined Jun 25, 2006 Messages 70 Location South Staffs Car Mercedes S204 I cannot see how to remove the plastic fan surround, any advice please...
May 11, 2011 #2 Doodle MB Enthusiast Joined May 3, 2005 Messages 6,282 Location Echo Beach Car KTM 1290SAR, Superb 272 wagon V6 or I6 motor?
May 11, 2011 #3 OP OP diandave Active Member Joined Jun 25, 2006 Messages 70 Location South Staffs Car Mercedes S204 DolphiN Tech said: V6 or I6 motor? Click to expand... Sorry should have stated 16.
May 11, 2011 #4 Doodle MB Enthusiast Joined May 3, 2005 Messages 6,282 Location Echo Beach Car KTM 1290SAR, Superb 272 wagon Well, I've got to do mine in the next couple of days, I'll let you know once I've done it if nobody chimes in beforehand.
May 11, 2011 #5 OP OP diandave Active Member Joined Jun 25, 2006 Messages 70 Location South Staffs Car Mercedes S204 Yeh ok, thanks for your help.
May 13, 2011 #6 Doodle MB Enthusiast Joined May 3, 2005 Messages 6,282 Location Echo Beach Car KTM 1290SAR, Superb 272 wagon May not be much help I'm afraid. Did it without removing the fan shroud.
May 14, 2011 #7 OP OP diandave Active Member Joined Jun 25, 2006 Messages 70 Location South Staffs Car Mercedes S204 DolphiN Tech said: May not be much help I'm afraid. Did it without removing the fan shroud. Click to expand... I'm going to change the tensioner as well, so dont think it will be possible without removing fan etc...
May 14, 2011 #8 Doodle MB Enthusiast Joined May 3, 2005 Messages 6,282 Location Echo Beach Car KTM 1290SAR, Superb 272 wagon No, I suspect not. You may find yourself taking the radiator off too then, as the shroud seemed to be responsible for the mounting of the rad.
May 14, 2011 #9 J jefrs Active Member Joined May 30, 2010 Messages 616 Location Berkshire Car S210 E320 Avantgarde '98 full load It unclips. You need a black belt in origami but it does then lift out past the fan.
May 14, 2011 #10 LowMilerAMG Active Member Joined May 3, 2009 Messages 265 Yes, def comes away unclipped from the rad.
May 14, 2011 #11 OP OP diandave Active Member Joined Jun 25, 2006 Messages 70 Location South Staffs Car Mercedes S204 jefrs said: It unclips. You need a black belt in origami but it does then lift out past the fan. Click to expand... So you dont have to remove fan first?...
Jun 7, 2011 #12 0121MB New Member Joined Jun 7, 2011 Messages 5 Car Mercedes To replace the belt and tensioner you will have to remove the electric fan remove bonnet slam panel to gain access and remove the o/s gearbox cooler pipe to the rad
