clk w209 brembo front caliper
astamir
london
w208 silver clk55
Hi guys needed a passenger side front 4pots brake caliper.
Damaged the bleeding valve on mine so only need the case itself without the auxiliaries.
The brembo part number is 20791502.
As far as I know the calipers from clk500 clk55 clk320cdi some C classes have the same ones also the slk350 amg models sharing the same calipers.
Cheers
C55 c32 compatible as well if anyone has them instead of w209 ones
BCS in Nottingham can refurb the calliper(s) or even just do the repair.
This might be the quickest option.
