DrX
Hi all,
I have just been reading merc5*'s saga and I am impressed with the patient responses of all the experts on this panel. That was painful! And it's not over yet! Hang in there merc5*!!
I have done my homework on this, and I would just like a bit of clarification.
My ML320 was built in Feb 2002 for a RHD market, and it's somewhat different from all the descriptions of MY2002 wiring I've read. From Richard's photos, I gather it's the same as his.
Under the RH (driver's seat) are a pair of loose FME (m) and (f) connectors, taped to what I gather is the diagnostic socket.
Behind the dash is WICLIC (=FME(m)?), FM/AM antenna, A/B, C, D2B, mini-UHF and an 8-pin socket of some kind. (photo thanks to Richard)
In the roof is antenna foot A163 820 16 75 but no blue FAKRA connector to be found.
My plan is to mount the GPS/GSM antenna (A163 820 18 75), connect the FME connectors under the seat together, and use the C to C1/C2 convertor loom (A163 540 78 10) to connect to the COMAND head unit. I thought I needed a GPS splitter/amplifier (A163 820 12 89) and an extra cable, but I think I can get away without it.
Will this work?
And where does the other end of that mini-UHF go to?
Thanks for your comments,
Doc
Will this work?
Doc
