Can the 180mph clocks be retrofitted BTW? Or the E63 clocks?
Recently there was an E55K up for sale with just over 200k miles on.How does the 55k handle higher miles? Would you walk away from a sub 10k car?
Can the rev limit be raised above 6500rpm on the E55?
AngryDog said:Can the rev limit be raised above 6500rpm on the E55?
No need, you'll be backing off, or hard on the breaks before then.![]()
Mine has been mapped and it rpm is nearer 7k than 6,
I like revs. My M5 revs to 7k, just wondered if it would be possible to do the same.
As mentioned though, doesn't seem needed which is fine. I want to make sure that I can shut down some supercharged M5's in the process as well. Petty? me? maybe LOL
Ball park, what does it cost for the headers, pulley, tune and tcu remap? And at what point should I be considering the upgraded I/C pump?
Do the pump regardless if your modding. Speak to Acid, i had 77mm pulley kleemann headers from him for a few grand, with the Dyno runs. Did my split cooling with two i/c pumps myself, & some other stuff.
Thanks.
Is the split cooling a necessity? Is there a guide on this anywhere?
Is it also worth going for larger injectors?
I'd say cooling upgrades to keep the iats low is needed for 77mm pulley. What are you planning on doing with car?
