Convenience window opening is erratic
Norse
Bodø, Norway
W211 280CDI T, W212 350CDI T 4MATIC
Hi
It has been sunny and quite warm for northern Norway the last few days, and I sometimes like to open the windows using the convenience function, but it doesn't always work. Wether I have the key 1" or 10" from the doorhandle doesn't matter. On my w210 it would work from 2-3 feet away without problems. Batteries in key is ok, and the key is pointed directly at the receiver...
Anyone got a clue??
Thanks.
Infrared sensor on door handle, then. A bit tricky to remove on w203, dunno on w210
Had the same problem..
Could it be interference from the bright sunlight? Each time it didn't work for me the IR sensor was facing the sun, otherwise worked fine?
