W1ghty
Every day is a blessingTo be precise, time will only tell if it didn't help......
Waxoil ! I did an old van with it once , heated the 5lt tin up in hot water, sprayed it on a hot day . Was dripping out every nook and cranny of the doors and bodywork for a while until it went solidOne thing you could do ( or get the mechanic to do) is that before the new subframe is fitted, get it sprayed inside ( especially inside) and out with a good protective coating. There are several good coating available for this if you google it. I remember once upon a time, there was a long flexible probe, with a type of head on it, that resembled the head on a drain jetter, and it sprayed literally in every direction.....if you drilled a small hole in a 25 ltr container, and inserted it, every square inch internally would be covered. At the time, we used a protective wax. It was liquid in form , but hardened enough to form a thick protective coating.
Petrol Pete..... anyone who mentions "waxoyl" ( or Waxoil) is making a statement about men "of a certain age...." The ones who remember it, that is !!!Waxoil ! I did an old van with it once , heated the 5lt tin up in hot water, sprayed it on a hot day . Was dripping out every nook and cranny of the doors and bodywork for a while until it went solid
Surely you don't need a full dealership service history because, didn't the European whatsit change the rules that you can take your vehicle to any garage for warranty and service ?ps
If you have full Mercedes Benz dealer service history
Ans) No I don't , so obviously Mercedes will try and wriggle out . So in other words, if you don't, your sub frame will rot in under 13 years!
At the age of these cars, you're in goodwill territory. However, I suspect MB are doing most of them to avoid a recall.Surely you don't need a full dealership service history because, didn't the European whatsit change the rules that you can take your vehicle to any garage for warranty and service ?
