- Dec 18, 2015
- E55k AMG Sold / S211 E320 CDI I6 W212 E63 6.2 N/A saloon.
Just after some advice regarding the recently purchased Ctek mxs 5 charger I now have.
When I first received the charger and attached it to the car, few weeks before Christmas. I put it on the AGM setting and the car setting. It went through its process of starting at 1 the 2 the 3 then on and on. Eventually sitting at option 7 I think it is. A full green bar basically. When I checked it over every other day it would be still at the highest setting, no 7.
So when I use the car I disconnect the plug, then disconnect the crocodile clamps I have on the negative and positive under bonnet terminals.
So I have done this now say 7/8 times. Is there a correct method in disconnecting the Ctek charger or does it sound like I'm doing it correctly. Should I turn it off on the actual charger or just unplug as bern doing.
I ask this because yesterday when I returned after driving the car, I attached the ctek straight away before allowing the car to cool. Then when I returned to it today, the charger bar was only sitting at option 3/4 I can't remember exactly. It's as though it wasn't charging. Am i using the charger incorrectly or am i doing something wrong?
Thank you.
Tom
Thank you.
Tom
