Custom Parktronic Install
R2D2
C350
This mod was inspired by R2e's thread http://www.mbclub.co.uk/forums/showthread.php?t=35863&highlight=parktronic
Hats off to R2e for such useful information!
I decided to buy exactly the same kit as R2e as the sensors looked so good but I wanted to try to replicate the parktronic display in the rear of the roof lining.
I ordered the kit which cost £30 and was pre sprayed silver:cool:
I also bought a parktronic rear display from a contact. The hard bit was always going to be the fitting.
I remember R2e's advice and found the retaining screws before pulling the bumper trims off as per his instructions. I drilled the holes using the hole saw provided with the kit exactly where the parktronic holes are already marked on the inside of the trim.
I reassembled and unlike R2e i took my live from the reversing light wiring and earthed to a bolt (eventually!)
The main difference in my install was the modifying of a standard parktronic screen to take the units lovely , but different shaped, display. Basically I used a jigsaw, knife saw and pliers and three hours later made it fit. The important tip is remove the clear plastic glass and then mask the inside black to hide the edges of the new display.
The finished item is in my gallery. http://www.mbclub.co.uk/forums/showthread.php?p=392041#post392041
Hope you enjoy:bannana:
very nice installation!
Well done Greg!
Mine has a factory fitted parktronik, but it doesn't show the remaining distance as your do!
Do you have/plan something also for the front?
Wonder where the factory rear display is for the W202.
Its on the dashboard. One in the centre of the dash and one over at the drivers side on that flat bit between the trim and windscreen.
Passenger rear door I think, ie over your left shoulder.
According to the EPC the display in built into the rear dome light chaps!
hmm , you sure? I could have sworn that my setup was the one they went with. Who can go to a W202 and look for the dash where it goes from the airvent to a flat in the middle and next to the drivers side A pillar as it angles round and conform these exist and that ive just not had too much caffiene :)
Oh, I meant to say. In order to get the display into the roof you have to remove the C pillar Airbag SRS badge then undo the Torx screw and unclip around the edge. I fed a stiff wire from the rear light hole in the headlining out to the edge above the C pillar and then tied the display to it in order to pull it back to the centre.HTH.
Very nice work there Greg ... I see the modding bug still hasn't lifted .. you do seem to have an incurable case !
S.
Now that is a great mod :rock: :rock:
saw a 1998 W202 C220 Diesel with parktronic OEM install.
Display as i said on the top of the dash with both displays there and not on the dome.
Saw a 2000 W220 as well with a similar location.
You didn't happen to catch the VIN did you? :)
I have 3 displays on mine.
1 in the middle of the dash, 1 on the right of the dash and one in the roof at the rear.
i looked dodgey enough crouching down and looking inside a car parked at the side of the street lol :)
