Eurico, Thanks for the THANKS. I don't often get that. My experience of solder is that it is weak and brittle. I am surprised that solder had the strength to take this.LAST RESORT MEASURE:
some time back I was changing the timing belt of my faithfull Clio and two miserable 8 mm screws where glued stiff and would not budge with any ammount of violence and cursing. I placed a large nut over each and soldered them carefully. They came off so easily as if they where finger tightened! It was the bloody glue that was used by a Renault dealer mechanic that created the situation. I believe the Merc diff plugs also have some sort of glue, so heating may destroy the bondage.
BTW - great post you did on ATF change.
I done a 1 week course on soldering technical in Austin Texas,(work paid for it,) and the key to soldering is heat accross all to be joints, cleanliness and flux. (Flux is the key component) A "Brazing" with a brass rod or maybe a tack weld I could understand.
Maybe 8mm can take a solder join, but not a Diff rusted filler tapered plug. In this case, rust is definately the problem. Not glue.
