T
tanuie
Guest
Driving along as normal and drove onto a gravel drive, I noticed that there was a noise coming from the back wheel, thought that I might I have picked up bits of gravel in the handbrake system. After driving back on tarmac, noticed the noise was coming and going, after a couple of miles it was getting worse, so stopped and looked underneath and everywhere else so I thought. Carried on at a slow speed and I thought it may be the drive shaft from the diff to the wheel hub so phoned the local Mercedes garage that I use and asked them if they would check it over. However going to the garage which was only four miles away, however when I was only 1/2 mile away the nearside rear wheel fell off. On a quick inspection all but one including the locking bolt had disappeared, so they seem to have all come loose. The wheel was jammed under the car and snapped the caliper off as well. So phoned the AA for recovery and took it to the garage by which time was closed, so it is left there until Monday morning when I will phone them.
My question is why would the wheel bolts come undone when they were put on about two weeks ago when new tyres were fitted so done up with an airgun. The wheels are 18" AMG with a ET front 38 and rear 39. The ET for a CLK is front 37 and rear 32, I know these wheels do not match the CLK so 15mm spacers were fitted, the bolts were long enough and there were no issues of rubbing anywhere, so how did they come loose. On hindsight it would have been simple enough to tighten them up, but in 45 years of driving I have never known this to happen.
Many Thanks.
Many Thanks.
