I'm at a loss with what to do with my '95 E330D estate's heating system.
It started blowing cold whatever the heating control setting a couple of weeks ago. The engine runs at about 80 degrees as normal.
The duovalves are working, although I've stripped them down twice. I've flushed through the heating circuit twice with a hose until it ran clean (after the first time, I had heat briefly). The recirculating pump is also working.
The pipe taking the water feed from the engine side to what I think must the heater matrix is hot. The pipes either side of the duovalves remain cold.
I took the top off the duovalve when the engine was hot and revved the engine. Water pumped through the duovalves, but it was cold, even though the engine side was hot. This suggests the heater matrix is not blocked but I might not be fully understanding the heater architecture.
Does anyone have any idea about what might be going on here or where I might next look?
Thanks.
Thanks.
