kth286 said:stats007
No movement of the coil feeds need take place to snip away the outer cosmetic coverering of the wires to the coil connections.
By gently snipping a couple of inches of the material with a nail scissors, one can then easily see the condition of the actual loom wires and (cracked)insulation, if indeed they are cracked.
As I say the outer covering is just cosmetic and black in colour to match the rest of the loom, and give the loom a uniform look. No harm done at all BUT big peace of mind.
Perhaps you have never worked under the top engine cover of a HFM 104 engine.
The loom doesn't just rot inside the cover - though it usually goes first here due to the heat buildup - any inspection elsewhere, the bulkhead for example, creates the same problem. It isn't limited to just the M104 engine either. I'm sure you've read Derek's thread on the MBOC - from memory didn't he make a loom for you as well?
