nick mercedes
They are rebadged VARTA batteries
Turns out they're both made by Johnson Controls:
Varta and Bosch BY JOHNSON CONTROLS
And it turns out Johnson Controls supply MB too.
If a battery was not vented it could cause the casing to crack and shower acid under pressure.
Normal and gentle charging should not cause any problems.
My bad, Downgrading is something I've seen all too often - Sometimes people think they can save £50 by chucking a 063 in a 3litre diesel, and then wonder why,
a) The battery cooks from the over charge
b) the battery fails trying to turn over a massive diesel engine
The then walk back in, and expect to honour a warranty
In you case, as you know - chucking a slightly more powerful battery is a fine
In terms of batteries, We are working on a dedicated section,s o you can search batteries by their UK Ref - However im worried that the CONs of allowing this outweigh the PROs
If your looking for a big battery - the 019 is a chunky battery and packs a punch, you can search for it on the website by using the following links:
UK017 - (95AH)
Bosch BMW S3 Battery 017 3 Year Guarantee | Euro Car Parts UK
UK019 - (100 AH)
Bosch Audi S4 Battery 019 4 Year Guarantee | Euro Car Parts UK
How about a 100AH battery as this is what originated from the car?
Any linky links?
Cheers.
forget about that, got it there:
Bosch Audi S5 Battery 019 5 Year Guarantee | Euro Car Parts UK
Most if not all modern cars have vents in the boot too. Though from what I understand this is principally for HVAC systems and to allow doors to close easily (cars too air tight will need the doors slamming), rather than battery venting.
I don't think it's to allow the doors to close, but for general ventilation.
You know Olivier, you can phone the branch anytime and get advice/part number from us. You can use the part number on the click and collect and still get your 25% off. You must be due for some fuel filters soon anyway
Sean....
Bizarre as it may sound that someone can make a living from it......but I co-wrote some software to analyse and optimise cabin venting for door closing effort..........And people wonder why premium cars cost so much
Pretty sure they can give off hydrogen sulphide if damaged, and that is poisonous
cheers
Any linky links?
Cheers.
Is there a technical reason why 096 format batteries do not exceed 77Ah, or is there simply no demand for higher capacity batteries in this size?
Thanks.
