Reading this i still think you are not eliminating one of the most common causes which are the injectors.. For what you have spent you could have had a new set for around £300 and they are easy to fit...
The reason i ask is tht i have a slightly smokey 270 CDI, i've cleaned the EGR valve QUOTE]
is it easy to do? How to proceed?
How to proceed in order to dismount pipes, ecc
Are there any photo on line?
thanks so much
I saw the photoes posted by Parrot of Doom times ago but mine is a 270cdi engine, quite different![]()
thanks so much
No pics i'm afraid, but its very easy. Remove the top engine plastic trim cover, the silver one. Underneath you'll see a large black pipe going into a metal unit. There is a metal U clip which hold the pipe in place. Remove the clip and remove the pipe. You'll be able to see in there if its blocked or not.
If it is you can either try and clean it in situ or remove the unit form the car. Its a bit fiddly and you'll need the right tools to remove.
£300 each is more like it!
thanks a lot for the appreciate info![]()
Ok so remouving that black pipe is quite easy, further dismountin seems more complicated, I'm wondering to clean it in situ, may I utilize WD40 spray to clean it?![]()
Please a clarification: with engine switched off is it possible to well cleanit, since, may be, it's in closed position![]()
Thanks again
Marco![]()
PS: I don't have any specific problem at the moment, I only intent to perform a "prudent" maintenance:bannana: , someone will say, don't touch anything that work without troubles
Nah they cant be any different to the ML ones which you can get at a good price from Euro, GSF etc...
They're £185+VAT from Euros if i remember correctly.
GF strikes again eh...
I normally bounce Euro GSF and KMS off each other until one gives me a price i like, they compete with each other fiercely in coventry..
Ok so remouving that black pipe is quite easy, further dismounting seems more complicated, I'm wondering to clean it in situ, may I utilize WD40 spray to clean it?![]()
Please a clarification: with engine switched off is it possible to well clean it, since, may be, it's in closed position![]()
Thanks again
Marco![]()
up please,I apologize if my english is not perfect, hoping at least is clear
thanks
any joy?I will find out later. Just sifting through some info on EGR.
