Facelift Audio 20 with Bluetooth retrofit in B Class?
also, did your car have the AUX already> In which case did you need a new loom for it or did the white connector just go into the new unit without mod?
Hello basically where the mics are mounted in my b class had a different plug to the one on the loom so you need to cut this off and join the wires.
I don't have an aux in the mp3 CD function does the job just fine.
will it fit Aclass
Hi I know this is an old thread but am i right that
A1699002000
will fit a 2006 aclass that has the audio 20(2) and i will i need the kit for mic etc from command if so ?
At present i have a merc bluetooth adapter in centre console for the phone,so its really ti update for music but would then also update phone i guess.
thank you
A1699002000
thank you
Yes it will but you will need a conversion kit;
https://www.commandonline.co.uk/NTG2-NTG2.5-converter-kit.html
Thank you Alfie :)
then I think my nice new old merc a200 will be getting a treat soon .
can any one identify this for me please
Hi Alfie has kindly answered the most part of a thread i started
http://www.mbclub.co.uk/forums/electronics/218551-help-2006-a200-upating-music-system.html
But I just wondered if anyone knew what this plastic knob /cover could be for in the picture on the left in the thread . It doesnt look like it wants to come off easily .
thanks all i appreciate your help with my questions
No idea what the cover is. Its not standard. I can only assume someone had something put there aftermarket such as SmartNav and subsequently had it removed and a cover/grommet placed over the hole. I wouldnt pull it off if I were you!
Hi would that be the same for a March 2006 aclass which has audio 20 ,or will I need extra bits as well
Thanks ..I'm still having problems understanding quite what I need lol
The trim panel in the eBay link above would fit.
It will replaced your modified panel with that unsightly round cover piece.
