FAO Graham C230K
BaldGuy
Berkshire, London & Devon
No longer a Benz...
Graham,
I saw your posts on the Benzsport site regarding the AMG look Exhaust tips from Japan for the whole Benz range, did you manage to find anymore out about these as I would club together with you to get some if your interested mate
leme know
You know they're about £100ish, and you will have to import from Japan...?
You know you want one of these:
They looked good didn't they, but I have not put any effort into finding any UK suppliers.
£100 is a bit steep for 3 inches of bolt on chrome trim though!
If my back box ever goes (which I hope it doesn't), I would consider the AMG replacement accessory (not a cut up C43 original likes Shudes).
If my exhaust failes before I sell the car on, I will be upset though!
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (GrahamC230K @ Nov. 06 2002,11:11)</td></tr><tr><td id="QUOTE">If my back box ever goes (which I hope it doesn't), I would consider the AMG replacement accessory (not a cut up C43 original likes Shudes).</td></tr></table><span id='postcolor'>
Mine is not a cut up original! &nbsp;It is a 100% stock c43 exhaust rear section! &nbsp;There is a sleeve welded onto my old pipework so the c43 exhaust pipe fits, that's all.
The c43 exhaust rear section is £600, the accessory version is £700.
Guys,
I really can't spend that kinda wedge on a Zorst when the one on there is perfect....
Your right though £100 is steep for the trim Graham..
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Wheelie @ Nov. 06 2002,12:51)</td></tr><tr><td id="QUOTE">Guys,
Your right though £100 is steep for the trim Graham..</td></tr></table><span id='postcolor'>
I rang Motion Styling in Bradford, they said they'd custom make me a complete stainless exhaust with oval AMG style tips for £250, including fitting. &nbsp;Maybe you should speak to a local exhaust shop, see if they can make something up for you, maybe just weld the tips onto your current exhaust?
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Mine is not a cut up original! &nbsp;It is a 100% stock c43 exhaust rear section! &nbsp;There is a sleeve welded onto my old pipework so the c43 exhaust pipe fits, that's all.
The c43 exhaust rear section is £600, the accessory version is £700. </td></tr></table><span id='postcolor'>
Shude - I just re -read my post. It sounded worse than I meant!
I know your exhaust is a complete original C43 item, I just meant that it wasn't designed to directly fit our cars. &nbsp;<img src="http://www.mbclub.co.uk/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'>
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (GrahamC230K @ Nov. 06 2002,13:55)</td></tr><tr><td id="QUOTE">I know your exhaust is a complete original C43 item, I just meant that it wasn't designed to directly fit our cars.  <img src="http://www.mbclub.co.uk/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'></td></tr></table><span id='postcolor'>
Yep. &nbsp;I might have considered the accessory version if I'd known it existed (#### stealership denied knowledge too). &nbsp;The old c230k box was puny compared to the new c43 one, it's twice the size! &nbsp;When I turned up to the garage to check on my car I heard a fantastic deep rumbling noise coming from a car and I thought it was my dad's porsche (in for a re-spray), but when I turned the corner it was my own c230k being backed out of the garage side-door, because of the larger box and slightly larger diameter pipework the exhaust now makes a pleasant rumbling noise - the accessory item will not do this (see Koolvin's AMG accessory c36-style exhaust - it's silent). &nbsp;Plus the c43 exhaust is cheaper <img src="http://www.mbclub.co.uk/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
You could try these people for a quote on a complete stainless system. Longlife Stainless Steel Exhausts
They quoted me about £200 for my C180, I thought I had a blow but it was just a loose joint so I never had it done.
They can make just about anything you want and make it sound how you want too.
