Forward Drain Holes C203
trapperjohn
Lancashire
124 300D 24V Estate
So gave the C270 a wash off this morning and I have a "well" of water collected near the N/S windscreen wiper.
I guess somewhere there is a drain hole down at lower body level which needs a judicial poke. I'm used to the "in you face" simplicity of a 124 drain holes not covert stuff on this millenniums cars.
Could anyone point me in the right direction of a drain hole please.
I thank you.
I thank you.
I`m new to Mercedes but i expect your C class scuttle is the same as my 2006 C class scuttle!
I checked my drain holes yesterday and although no puddles the passenger side / near side one was blocked lightly at the end of the flattened pipe where it goes behind the bulkhead heat shield.......you can`t see where it just plugs onto the scuttle as the large wiring loom goes over it and you have to push it gently to one side so to unclip the pipe from the scuttle ......
Hope this helps?
Stick yer finger in and whirl it around John. It'll be moss off my roof! The blockage will be in the tray, not in the pipes. I have to do this about once every 3 months as I park the car at the North side of the house and the birds are always rooting around on the roof and chucking moss on the car!
