- Nov 22, 2008
- Location
- Leeds, West Yorkshire
- E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
I did a job over the weekend - Changed the main fuel filter and the pre-filter on the E300TD.
Not difficult.
I had the parts, including the replacement O-ring seal for the pre-filter housing.
In the box with the main filter cartridge, were two O rings ... One slightly larger than the other.
I used the larger O-ring to replace the one on the hollow bolt.
The other one appeared not to be required, so I refitted the parts in the same way they came apart.
The engine required a fair bit of cranking to get it to bleed the air out of the injectors.
It gave me a few rude messages on the dash.
But, eventually, it fired up and all is running well.
Except .........
Looking at the diagram on the Russian site suggests that both O-rings should have been fitted.
I don't know where the small one would go.
I didn't see it during dis-assembly.
Can anyone advise me please.
I've got the same job to do on the other E300TD in the next few days.
Thanks in advance.
Not difficult.
Except .........
Thanks in advance.
