Disconnected the fuel return line at the n/s sender unit and diverted to a jar via an 8mm hose with a 2mm nozzle at the end (similar to size of spray pump nozzle) - started the engine and observed the flow on a range from idle (700rpm) to 4000 rpm.
At idle to 1000 rpm, there was merely a dribble - this is clearly not enough to drive the spray pump (cannot be design intent as the car would run dry in a traffic jam!). The flow incresed with rpm but with a considerable amount of air/vapour visible in the line - I am pretty confident that the fuel supply side is airtight so where does this come from !!!
Also spoke to MB Head Mechanic at nearby town - told him I had replaced engine bay fuel pipes, rail regulator, sensor and lift pump and that no HP pump leakage - he said try the following in order:-
1. confirm no excess injector leak-off (confirmed virtually nothing at idle)
2. fit model-specific MB fuel filter and no other - said filters for pre and post facelift W203 220 diesels were different internally and that fitting wrong / aftermarket filter common cause of problem - resticts fuel supply rate!
4. replace the swirl pot in tank o/s - says this also a common cause of problem but says no-one knows exactly why - possible age-related internal distortion / internal separation of welded plastic seams
