On my list of to-dos is adding aftermarket bluetooth handsfree.
In the past I have fitted the Sony Ericcson HBC-700 system and it always works with my phones so that will be the one to go in.
I removed my last one from my old car and stuck it into the Smart Car. Works a treat and is a nice clean install.
So tracked a new one down on Amazon, and it will go into the S500.
I have a few questions.
There are a few components to this, hand control, speaker, control box, mic and LCD screen.
I will run the mic up the A pillar, and think I know how to remove it.
The biggest challenge is routing wires from the LCD and hand control. On the surface the dash looks like there are not may routes to run the wires through!
I can get a switched 12v feed from the fag lighter, & I should be able to find a perm 12v behind the Comand.
I found a yellow "mute" wire on my Comand. I will need this to tap into. Question is what is it doiing there? Were most cars pre-wired for the telephone. Unless mine used to have it (no signs), the mute wire runs off somewhere. But to what?
