I suspect there's a point between not enough to cause damage and enough to stop it starting that can inflict maximum damage. Around 20%?This is the best explanation of what will happen if it was misfueled, I would have thought 20% wouldn’t have caused that much damage though unless it was more than 20% initially and diluted again with more petrol. I think someone maybe has misfueled and the engine called quits.
hopefully not the case.
I think you have hit the nail on the head. I’ve just watched a video on YouTube where this chap purposely put diesel in a petrol to see the reaction. The result appears to be the same as the OP described it, serious knocking and power loss.I suspect there's a point between not enough to cause damage and enough to stop it starting that can inflict maximum damage. Around 20%?
Similar thoughts have been mulling in my mind - but I was stuck on the notion of a reserve tank that doesn't exist. Mulling it to the point of almost asking how much fuel was in the tank when the engine went pop. Now's the time to ask.Do these have a saddle tank?
Could diesel have been sitting in the 'reserve' part of the tank until the fuel level dropped?
Is it possible it ran on part diesel previously w/o obvious adverse effects at that time? From reading these posts that sounds feasible.
So is it possible from the initial introduction of diesel that this was a catastrophe in the waiting?
I wouldn't have expected diesel in a petrol to cause a catastrophic engine failure, but Bellow describes well how it might.
Back to the saddle tank theory, it was known on the 203 that a car could fail when fuel dropped to approx 30%, if the fuel transfer pump failed. Is it possible that an MB tech added some fuel to raise the fuel level so to eliminate that as a possible cause.? That introduces a possibility that the engine failed for whatever reason, as yet not identified, and the diesel content has now become the blame.
Hi , well other members have suggested that very thing. If you have a comprehensive motor policy vandalism should be covered.
The OP may find that when an Insurance company becomes involved the doors that were closed may be opened.
According to mercedes me app 24% fuel in the tankSimilar thoughts have been mulling in my mind - but I was stuck on the notion of a reserve tank that doesn't exist. Mulling it to the point of almost asking how much fuel was in the tank when the engine went pop. Now's the time to ask.
I've no experience of the app,According to mercedes me app 24% fuel in the tank
How many miles (from car last used) into that last journey before the engine failed?According to mercedes me app 24% fuel in the tank
I’m not sure you can, does anyone know if this is possible?I've no experience of the app,
can it be interrogated historically?
A graph of fill levels / time could be useful.
I can’t see fuelling history in the Mercedes Me app on iOS. Will have to see if more info is available via the web portal. Not used that before and don’t have my login details handy, so may be some time…Hi. You can on the Mercedes Me Adapter app so can’t imagine the info isn’t available on the newer system. Below are screen shots of what I can get. This would be useful for you as said. Really hope you get the outcome you want from this. Good luck!
Do you have to key in the price per litre and total amount spent ?Hi. You can on the Mercedes Me Adapter app so can’t imagine the info isn’t available on the newer system. Below are screen shots of what I can get. This would be useful for you as said. Really hope you get the outcome you want from this. Good luck!
I see, so that wouldn’t help the OP then to see any fuel was added without him knowing.Hi @geoffus. You have to enter the price per litre. It gets quite close with litres filled but I normally put the true number in too. It then calculates the total cost. I use the Shell Go app too so that logs everything accurately.
After fuel is added, the app automatically offers the added fuel quantity based on the fuel gauge. You can then do nothing and the automatically-detected quantity will remain, or you can amend the quantity manually.I see, so that wouldn’t help the OP then to see any fuel was added without him knowing.
