Help pleeease clk 230 kompressor "2002" error code p0702
sportscars
woodford green essex london
clk 230 kompressor
Hi there , you guys and girls,
Im new hear so you have to bear with me lol,
I've got my clk 230 kompressor w208 model and just started it after being parked up for 3 years.
It seems to of gone into limp mode .
checked with the diagnostic(basic laptop) and the error code P0702 has come up.
deleted the code and sure enough its back again.
so far i have.
put a new battery
disconnected the battery leads and connected them together to remove static that maybe on board
disconnected the plug at the front of the auto tiptronic box and cleaned and refitted
but to no avail
any help would be most appreciated as i'm a little lost?
do i have to have the gearbox ecu reprogrammed?
bear in mind the car has only done 20k
many thanks
Andreas
:bannana:
hi there,
many thanks for the replies you guys,
i,ve had the battery on charge over night and this morning fired her up cleared the fault with the diagnostics and there you go again its come back
P0702 is 'Trans Control Sys Electrical'
any more idea's to where i go from here?
Once again to all THANK YOU VERY MUCH FOR THE HELP AND ADVICE X
This code sounds more like it has something to do with the automatic transmission controller plate in the gearbox or the transmission ecu.
try changing the gearbox oil ? and driving it if possable, plates may have stuck as its not been used for a while
Holy Thread Revival Batman.
I think after 5 years he's more than likely changed the car.
Just be aware these cars are known for throwing wrong fault codes, so go back to basics and eliminate the obvious first,
