help with w211 NTG1 stereo set up
kalvin928
Watford.UK
S205 C63s , Lotus Carlton replica, CLK 200 Kompressor
ok guys
I am a bit confused here... my car came with the NTG1 unit which was not the original unit... I am not sure what was in there 1st. anyway there was a fault with the amp.. Harmon kardon as only played through LHS speakers... I sourced another one and all fine now. However I am stuck here, can someone confirm if the sat nav player will connect up this present setup? or will this only work if I get a gateway double tuner amp? if the case, then I am presuming I need to change all the cables to connect the NTG1 to this? I need to know so that I can then decide to remove the sat nav player which is presently sitting in my boot doing nothing!! also I bought an anologue tv tuner... I only wanted this so I could plug ipad 3 in with composite but will this connect to the harmon kardon amp? or again its the Becker one that is needed..... does any of this make sense to anyone??!! if so please help and thanks
ok guys
You do not need the dual tuner AGW for the navigation to work but it helps for dynamic routing.
The Navigation drive just connects up into the MOST loop and should work straight off.
