DieInterim
- Sep 12, 2007
That's a fantastic post Blake, welcome aboard.
When first reading I was thinking of a vacuum leak, nice to know it was.
Did you also sort the non return valve and accumulator issue to assist with hot starting?
Well I ordered a new check valve and accumulator, I will let you know what the result is. If the injectors are still leaking I will replace those too. I am also thinking about replacing the proximity sensor for the ignition; the engine simply bucks and stops accelerating when rpm's approach 5200. It may be something else, but my hunch is that this is an original sensor and it may be tired and out of specification.
Regards,
Blake
