SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
Good man. Informative video otherwise- you do get a taste of the forces that need to be applied in doing this job and a hint of how you sometimes have to persist for quite a long time to gain success.
atleast with the arm (nearly ) off i can see that its very possible this is the cause of the creaking - the balljoint is shot and all the other bushings at the mounts look pretty tired & dry/cracked rubber.
after this job, all i have left to do is to renew the coolant (it just has water in at the moment), fit a wheel arch liner that was smashed up when i got the car, and replace some broken trim inside the car and hardwire in my wife's satnav 'cause the bl00dy alfa cig lighter doesnt seem the same as normal ones and the power supply keeps on falling out of the socket.
then i can relax and put the R107 back in my garage (currently living out in the cold rain )
